USB Copy - Not always 100% consistent
I use the USB copy application in Synology with an external HD to backup data. I have 5 out of 6 backup settings that are small folders with a couple of documents, I have no issues with the data transfer. I am NOT having the same success rate with 1 folder with many sub-folders and hundred of thousands of documents, USB copy app states “Successful - Last Execution Succeeded” however when clicking RUN again it keeps copying files which seems that the backup was not completed at 100%. Any help on the topic is appreciated.
What is the hard drive formatted to? I only really trust synology with ExFAT or EXT4
Thank you for your answer, I checked the format, it is EXT3/EXT4, I will format the HD in ExFAT to see if it works. An will post the results once all done. Thanks.
Update: the external HD has been formated in ExFAT, also I have installed the “ExFAT Access” application on the Synology. Synology is seeing the HD in ExFAT, started backups. More to come regarding transfer results.
Same results using ExFAT, the backup states successful but when clicking run again it copies documents for 3-4 hours, then I get successful again, click run and there are still files being copied. Maybe after many iterations it will work (?). I really don’t understand the logic behind this issue.
