About the General category
Create topics here that don’t fit into any other existing category.
Topic: Starlink Gen3 wired to Unifi Dream SE.
I enjoyed the video of Unifi compete setup. All seemed to go well after the reboot worked and ability to make settings.
I could not get the WIFt working. Message Config will not be set up untill set up access point.
I have One Dream SE, Two Wave-Nanos Two Swiss army knifes, Two USW-flex 46watt going into the utility box. All power up fine but only the one wave nano wired in is recognized.
Next the Internet blinked off and on. i did some research and saw someone had to add a cross connect able so i tried that and the internet still blinked off and on. Curious if someone has written cabling diagram for connecting the SL Gen3 to the Dream SE so i can make sure I am correct. I tried through the older ethernet adapter and direct into the SL Gen 3 at one of two ports. Then through a Switch.
I tried using the gen 3 router ethernet port. and also removed the SL router completly and pluged in the SL dish cable direct to the Dream using the ethernet adapter. Internet still randomly off and on.
All advice, diagrams are appreciated.
Richard
