Bitrot, data decay, corrupted files - is there a soft to analyze and fix it?
I believe that my first NAS (DS411j) caused bitrot on some of my files. I did however, had the copies of some of the same data on other storage. During the years, I moved this data to a couple of newer Synology NASs. I suspect that some data degraded over these years.
My question is - is there a built in feature, a package, or a soft that can be ran on the NAS in container, that could go through all of the files on the NAS and find the ones that are corrupted?
More importantly, find duplicate files and show which ones are good and which ones are corrupted?
And how to prevent this problem from happening in the future?
Newer models support and use the Btrfs file system instead of EXT4. This file system has features that prevent bitrot.
With few exceptions, you cannot repair corrupted file without a backup or parity volume.
Thanks for reply.
Is it something done on btrfs automatically by default, or this feature has to be turned on?
I do have a backup.
But how do I automatically replace all corrupted files without replacing all the files ( the back up also may contain some bitrot affected files )?
Is there an app that can automatically identify corrupted files and replace them with good ones from another source?
It may be too late for that now. To attempt this, you would perform a file by file comparison using command line tools such as diff (Linux) and fc (File Compare, Windows). If a difference is detected, only you know which file is correct (as it’s possible that the “backup” is corrupt).
It requires user action. Long story short, you must enable data checksum for each shared folder when it is created. You can not enable it afterward. Second, you periodically (once/6 months) run a process called data scrubbing.
