Can't get Hyper Backup to Login to NAS - Same Network
Hi!
I have a DS418 and a DS216j both connected to the same network. DS416 runs backups into DS216j using Hyperbackup. Everything is been working perfectly fine until my DS416 memory got full. After messing around with the software trying to reduce backup size and copies, I´ve decided to start from scratch, erase the backups I had in the DS216j and start all over again:
1/ started a new task in Hyperbackup while having the vault open in the other NAS.
2/ Selected connect to remote NAS
3/ The other NAS is detected and selected to connect
4/ I keep encryption off and port 6281
5/ When I press the Log In button, the login pop-out window appears
6/ I introduce the login credentials, it does login, the pop-out window closes automatically. At this stage on the previous DSM window I´m not getting the connection since I cannot select the shared folder. I can press the Log In button again and the pop-out window will come up, allowing me to log in again and come back to the same situation.
Please advise what do you think is the problem. The configuration for both NASs is exactly the same as it was before I erased the task and everything was working well.
Thanks in advance.
