Is there a way using quickconnect to directly access my synology drive remotely? Something like quickconnect.to/username/synologydrive.
Thanks
Thanks
Try this: http: or https://Your ID.direct.quickconnect.to/drive
Doesnāt work for me. Is there a specific port I should make sure is forwarded?
Yes, there is an alternate URL;
http: or https://Your ID .direct.quickconnect.to:RouterPort#
Go to the āRouter Configurationā tab of your NAS. There are two port columns, Local Port & Router Port. Since you want to enter the NAS from outside your LAN you need to use the Router Port configuration for QuickConnect. If they are both the same number then you may have a bigger problem. Post a screen shot of what happens.
I canāt use the router configuration on the synology nas because I donāt have one of the listed routers.
Even if Iām on the LAN and I type in the IP of the synology nas/drive it doesnāt work. For example 192.168.1.1/drive
I just donāt know enough about your setup to give you anymore constructive advice. If you canāt provide details about your LAN setup and the settings on the NAS and router then there is nothing I or anyone else can do. If you want help you need to provide details. That way we can know if I can help or not. Good luck.
Short answer: yes. But you need to set the alias ādriveā in Control Panel > Login Portal > Applications tab; select Synology Drive and fill in the alias.
No need to open ports.
That was it! It worked! Thank you both so much for responding.
