Drive failures since installing in Synology NAS
I purchased a DS925+ and installed some WD Red drives in it.
Within a very short time DSM reported two of the drives as having problems. Before I installed them in the Synology I did a Smart test on the drives and the result was 100%.
My questions are:
  1. Does this happen a lot?
  2. Is it because they are WD drives?
  3. As it now seems that I need to buy new drives are there any real advantages in buying Synology drives? These are quite a bit more expensive and the only reason Synology seems to say they are better is that DSM can update the firmware.
  4. As I’m new to Synology I’m quite shocked that the DSM would be reporting problems with the drives in such a short period of time.
If the Synology drives are more reliable I don’t really get why they only have a 3 year warranty.
I also have no idea what the warranty replacement process is like.
I’m based in the UK and I’ve no idea if that makes any difference.
Any words of wisdom would be much appreciated.
Exactly what did the drive “failure” notification state?
Before doing anything else, I would test these drives using a PC.
CrystalDiskInfo
