DS-1522+ to DS-1517+ mirroring/backup - personal use, not a business
This, in all likelihood has been covered, but there are such a plethora of options that I’m feeling overwhelmed by choice. Options are good, except when there are too many of them. :slight_smile: Also, I’m old, and inclined to favor the familiar, so rsync in a crontab entry would be my comfort zone favorite, but probably not the best in terms of someone else figuring out what I’ve done via DSM.
I’m currently in a copy and paste project to simplify the directory structure and copy the contents of the DS-1517+ to the DS-1522+. They are currently located within inches of each other. Once the files are copied over to the new NAS, and the shared folder structures on both match each other, I want to change to primarily using the DS-1522+, with all file additions, deletions, and edits happening on the DS-1522+. I want to routinely mirror the contents of the DS-1522+ to the DS-1517+.
I am also a huge proponent of K.I.S.S., which may also come along with being old. :slight_smile: My two NAS are personal media file storage devices. The shared directories will be; audio, video, photo, and reading (since my epub library wouldn’t fit under audio files, video files, or photography.) The files will not be subject to much change, so my feeling is I could power up the DS-1517+ once a week or so and mirror any changes from the DS-1522+ over to my backup NAS.
I’m looking for a balance between simple and safe. I’m not a business, and I don’t need a ton of options. I just need to do a reliable mirror with the files on the backup device readable if someone were to log into the backup device.
I think part of my hesitation is that ‘back in the old days’, backup software wrote off the backup into a proprietary structure, and one needed the backup software to recover anything inside the backup. I do not want something like that. I just want to copy a file from the primary to the backup if it doesn’t exist on the backup, and delete the file from the backup if it no longer exists on the primary. Simple stuff. And if the primary crashes and burns, then I’d be able to log into the backup and turn it into my primary media server without jumping through a bunch of hoops.
I hope I haven’t been too wordy, but I wanted to give enough background to what I’m looking for that any suggestions would cover what I’m looking for. I don’t want to say, ‘I’m looking for this green thing’ and have someone come back and tell me how well a blue thing works for them. It’s great the blue thing works for someone else’s needs, but I’m still looking for the green thing. :slight_smile:
There are indeed several options. Because you are more interested in a sync solution versus backup, the options narrow down (but are not limited) to:
  • Shared Folder Sync, which is basically rsync
  • Hyper Backup rsync (single file)
  • Synology Drive ShareSync
    The last option would be my favorite in this situation since it allows you to sync from A to B for now and back from B to A in the future.
What is not clear to me is whether you use applications on your NAS. If so, you need to copy the application data as well. If it is only files, than you are fine.
I did finally get this implemented last month after a far too long delay. The personal spur to finally get off my backside and do it was completing the construction on the new house, moving from an ISP-provided mostly WiFi network to my own mostly wired network, and a desire to finally clean up my home file storage mess.
I went with Hyper Backup of the entire Primary NAS to the Secondary NAS. I don’t have offsite done yet, but I now have far more than I used to have. The next time someone says “RAID is not Backup” I can stop hanging my head in shame…
