Hello everyone,
since yesterday evening, when I had a voltage drop at home the NAS turned off, the resource monitor stopped showing any values - it’s totally empty
Silence in logs and notifications. What can I do with this ?
thanks and best regards
Jul 25 17:40:30 Pablo coredump[2020]: Process snmpd2008 dumped core on signal [6]. Core file [/volume1/@snmpd.synology_geminilake_220+.64570.core.gz]. Cmdline [/usr/bin/snmpd -fLn -c /etc/snmp/snmpd.conf -p /var/run/snmpd.pid udp:161,ud p6:161,tcp:161,tcp6:161 ]
Jul 25 17:40:30 Pablo coredump[2020]: Core file [/volume1/@snmpd.synology_geminilake_220+.64570.core.gz] size [688689]
Jul 25 17:40:30 Pablo systemd[1]: snmpd.service: main process exited, code=dumped, status=6/ABRT
Jul 25 17:40:30 Pablo systemd[1]: Failed to start SNMP Daemon.
Jul 25 17:40:30 Pablo systemd[1]: Dependency failed for Daemon for Resource Monitor.
Jul 25 17:40:30 Pablo systemd[1]: Job synosnmpcd.service/start failed with result ‘dependency’.
I asked synology service for help. They stated that
After reviewing the log, there are multiple core dumps of SNMP occurred that caused the abnormal status of enabling SNMP[1] which might be caused by the 3rd party RAM issue. Our engineers are currently investigating this issue and will roll out updates/patches addressing the issue. We apologize for any inconvenience caused.
I had to take out 8 GB of RAM and run some commands to restart SNMP
mv /var/lib/net-snmp/snmpd.conf /var/lib/net-snmp/snmpd.conf.bk
systemctl restart snmpd
systemctl status snmpd
Kindly check if the status show “active(running).”
mv /var/lib/net-snmp/snmpd.conf.bk /var/lib/net-snmp/snmpd.conf
and so I confirm that this time SNMP was successfully launched, statistics in Resource Monitor are working again, and by the way integration with Home Assistant has started working again.
I asked if they’d improved anything else, but so far I have no information
It seems that certain processes are unable to start correctly and are encountering buffer overflow issues. The root cause has not been determined yet, and our engineers are actively investigating this matter.
