Hello,
after updating to DSM 7.2, “direct” quickconnect.to stopped working for me - NAS (DS923) will not create upnp request to router for port forwarding. Only static upnp redirects work. (eg for hyperbackup + PLEX) … any idea what to do with it? Thank you
So you now just have to manually forward the ports. Synology disabled UNPNP for quick connect on DSM 7.2
I selected the apps i need (DSM, Surveillance) in the DSM port forwarding settings and it seems to work. Thank you
