Was wondering if anyone testing out 7.2 RC has been able to successfully setup an NVMe Storage Pool?
I’ve got a compatible Synology (DS1621xs+) with two Samsung 500GB NVMe drives, but I only can create them as a Cache Drive, not a Storage Pool. Do they have to be Synology branded NVMe drives?
It would be great if they opened it up to larger capacity nvme drives, but they historically don’t like allowing larger drives from anyone other than themselves to be on the list.
Take it for what it’s worth, but someone posted on Reddit that he claims a Synology employee told him they would be opening it up to some other drives and not just locking it down to Synology drives. If not critical, I would wait until the official 7.2 release before spending the extra money. There is a chance (although its is small) that your drive makes it on the list if they do allow non-synology NVMe.
Correct me if I’m wrong, but I think it’s the other way around: you can only use 3rd-party M.2 NVMe drives for DSM caching, not as a storage pool. But I think that having a cache is more valuable, even if you have an all-SATA-SSD RAID instead of HDDs. For a fast & active storage pool, I’d probably go for something like the rackmount Thunderbolt DAS OWC Flex 1U4, which can house up to 16 M.2 NVMe drives using four OWC U.2 Shuttles, and set it up as RAID5 with SoftRAID. (It would be separate from the Synology NAS, of course, but if you’re using it for production like video or audio, you might actually want to keep it separate, and only use the NAS for project archival.)
(There is, however, the option to add single or dual 10GbE NICs via PCIe to the Flex 1U4, but I don’t know how you would set this up in a network environment. Would such a device be able to work as a rudimentary standalone NAS?)
My goal is to have caching read and write.
I will get available one device 256GB this week and was thinking to get another one (later as the prices now are very attractive) if write cache will be allowed. If not, then I will stash some cache for Synology.
Synology 800GB for $280 vs any better one 4TB for $200
