DSM 7.2, Ventura & TimeMachine giving me issues
I’m having a hard time setting TimeMachine on a mac mini running Ventura, where the destination needs to be a Synology NAS running DSM 7.2.
Initially tried over SMB, but kept getting prompts for the login to the destination (I even reset the password to be certain I have the correct info). On AFP, DSM gives me a warning it is not recommended for BigSur and above, but the TimeMachine lets me select the drive. That said, it won’t let me select a backup schedule (hourly, daily, …) or even start a backup manually. Any help is appreciated.
Hello, I would recommend active backup for business instead of timemachine, if this supports your nas
Unfortunately I can’t assist - other than to say that I am having the same issue - multiple Ventura Macs. I have given RW permission to the users for the SMB shareand have logged in - but Time Machine keeps prompting for password.
Have also created a Time Machine group and given accounts membership - group has RW to the Time Machine share - but still no go.
Still setting up my DS1621+ but have most things going now.
I used this How do I back up files from my Mac to Synology NAS using Time Machine? - Synology Knowledge Center to set up
I am using SMB (no AFP)
Cheers
FIXED
What you need to do is:
Control Panel > File Services > Advanced tab - under Bonjour tick enabled “bonjour Time Machine broadcast via SMB”
Ensure you select the shared folder you created for Time Machine
Then it works
Cheers
Thanks, that did the trick for me as well.
