Wondering why the Synology Drive Icons appear in different locations on my new M2 MacBook Air vs my old 2012 MacBook Pro? Is this just because the difference in their OS versions?
Are you referring to the top icon in the tray?
Or icon are you talking about?
#1 On my MacBook Pro 2012 running 10.15.7,
Thereâs a folder named âSynologyDriveâ in my user folder,
which I can drag to make an alias to in the Mac finder âfavoritesâ sidebar; and,
#2 On my M2 MacBook Air running 13.2.1,
Thereâs no folder named âSynologyDriveâ in my user folder, so thereâs no alias I can make in the Mac finder âfavoritesâ sidebar.
Both Macs have the Synology drive listed in the finder sidebar at /Locations/Network/QuickConnectName
and both Macs have âSynology Drive Clientâ in the finder âApplicationsâ folder.
Iâm wondering if this difference is just due to the different OS versions or if it reflects something I did differently.
Ah,
So the folder that is used for sync is chosen under the sync task. Check it out in the settings and you can put it wherever you want
Ah, I think Will actually answers my question in his YouTube video âHow to use NEW Synology Drive on Demand Sync for MacOSâ at @14:50, where he says the Mac system determines where the Synology Drive folder will be place. So this explains why the Synology Drive locations can be different depending on the Macâs OS version. Thanks again Will!
On my 2012 MacBook Pro running 10.15 the location is
/Users/waw4/SynologyDrive
so I see it there & can move an alias of it to the finder sidebar
On my new M2 MacBook Air running 13.2.1 the location is
/Users/waw4/Library/CloudStorage/SynologyDrive-nebula
and as it turns out, I can find it there & likewise move an alias of it to the finder sidebar
I like to use the folder aliases to drag items for storage on the NAS, with access from my Mac if needed, without having to store them on my Mac first and it also seems to me to be a faster and less cumbersome way to get files to the Synology Drive folder bypassing the Synology App.
Yeah, the âon demand syncâ for MacOS forces you to put the files in that CloudStorage library. But everything else should work as designed
