Whenever I try to do the “Map Network Drive” and type in \[NAS name], it does not work. When I try using the IP, it does not work. I turned on the SMB service and did those steps before the part where you map it. If you know any tips to fix this issue, please tell me about it.
I used two backslashes. However I got this mapping issue fixed by mapping it by using synology assistant. But I do want to find out why it did not work the way i did it (using file explorer).
It should work. Are you trying to map the whole server to a drive letter? Looks like you haven’t specified a shared folder in your path. You can only map a specific folder; not a server. Also, are the computer and NAS all on the same subnet?
