My TrueNAS Scale custom configs to maximize ram usage and use more metacaching
Wanted to add a list here of my custom configs that I use to change how TrueNAS Scale uses RAM. Basically linux ram could be as high as 2x usage then what its expected due to fragmentation, so this commit updated RAM usage in Linux ZFS to only 50%. This fragmentation is a worst case scenario, so I normally allocate it to 80%. Especially on high ram systems.
I also really like adding in more metadata in the arc talked about in this post here:
My ZFS parameters
Warning: Do this at your own risk, these are for my 128 gig setup, you will need to change the values according to your setup
Allocate 100 gigs as the max ram:
echo $((100 * 2**30)) >> /sys/module/zfs/parameters/zfs_arc_max
Allocate 30 gigs as the min ram (not really required):
echo $((30 * 2**30)) >> /sys/module/zfs/parameters/zfs_arc_min
Force at least 8 gigs of ARC to be used for metadata (really nice to have)
echo $((8 * 2**30)) >> /sys/module/zfs/parameters/zfs_arc_meta_min
I go over these in an upcoming video here!
Hi Will - I installed the beta version of TrueNAS Cobia (sp?) in my homelab. I’m not seeing zfs_arc_meta_min in the parameters directory, but I am seeing zfs_arc_meta_balance, which openzfs defines as
Balance between metadata and data on ghost hits. Values above 100 increase metadata caching by proportionally reducing effect of ghost data hits on target data/metadata rate.
Do you think they’re changing this parameter in the latest release?
Interesting! I have not seen this. Hopefully this means that as a default we will have more metadata in ARC
After updating to TrueNAS-SCALE-23.10.2, the metadata command doesn’t seem to work anymore. Has this happened to your system?
looks to have been replaced: ZFS "ARC" is getting smarter with version 2.2+ :smiley_face_emoji: | TrueNAS Community I set mine to 10k, let’s see what it does.
