Same UNC address via OpenVPN & LAN
Is it possible to have the same Windows explorer address to a folder on NAS when connecting via OpenVPN and when connected to LAN without OpenVPN?
So I have the router forwarding to 10.8.0.1 and the NAS has a static IP address on the router 192.168.1.48.
If it is possible what steps do I need to take?
I would like to use the same address on my desktop which is permanently on the LAN and my laptop which won’t be on the LAN when I am travelling
Since there is no name resolution via OpenVPN, unlike on the LAN, you should use the IP address of the NAS when connecting via OpenVPN.
That said, there is a trick when you install a DNS name server on your local network, on the NAS, for instance, and configure the OpenVPN connection to use that name server to resolve the NAS’s name.
So I can access my NAS via OpenVPN using IP Address 192.168.68.48. What do I need to add to this to access a folder \synnas\data?
Hi stefjan, I suggest you check out this post on this forum:
Will’s tip at the end might be your solution.
Thanks Paul, looks like lots of useful information there.
