Trying to setup sync task for Family folder as shown but there is no way to edit and create a new folder for it. Do I need to manually create a folder on my PC for each sync as there is no way in the synology drive client to do this?
You can create a new folder on your pc or use an existing folder. Go to synology drive client and set up a sync rule for that folder. You should have it sync to a new folder on your NAS. Anything put in that folder ( a file or another folder) will sync.
