Recently I have been unable to use SMB to connect my iMac to my Synology server. When I use the server IP address the iMac connects to the server, but using the SMB as defined in File Services\SMB it does not connect. The SMB is configured for Maximum SMB Protocol=SMB3, Minimum SMB Protocol=SMB2.
Two things occurred almost simultaneously: Synology Release a new SMB update, and I installed a new Mesh network. I don’t know how to determine which or both of the occurrences is causing the problem, or how to determine the cause of the problem and how to fix it.
Thanks for any advice.
Bill
