Hello,
Is there any way to view Synology’s DSM firewall logs?
Best Regards,
Wojtek
Hello,
Best Regards,
Wojtek
@wojtek I don’t think so. Most firewall software does not enable full logging as it would really slow things down, due to the massive number of connections that occur.
What you can see is any IP’s that have been blocked / successful attempt.
disclaimer: The following is not supported behavior, and could break your NAS (probably not)
If you really wanted to, you could enable UFW logging using something like this. Though do this at your own risk.
What are you looking to debug?
