hello sorry posted on the YouTube comments and no reply. Figure I’ll ask here.
i need help on the twingate video.
What are the firewall Port rules?
I can’t get twingate to connect if i turn on synology firewall with TCP port rules 30000-31000 and 443 as twingate website suggests.
If i disable firewall I can connect to twingate with no problem, but that is not good practice with no firewall rules on.
When you disable your firewall and connect, what IP do you see as connected in? You need to allow all access to the NAS from that subnet as that is what your IP is when you are connected via Twingate. If you want you can just allow all RFC1918 subnets
@Will Thanks! I allowed all RFC1918 subnets
and Twingate is connected with firewall rules on !
One thing I still encounter is
Plex doesn’t seem to stream video properly
via Twingate using this firewall setting (32400, 32469 port)
OpenVPN seems to have no problem with Plex
Any tips you would give for security concerns
and Twingate Plex streaming would be great help!
