Virtual Machine Manager - IP address is not show
Just installed Ubuntu. Everything went so nicely. Everything works. But one thing bothers me:
while
I can do SSH from another host to that IP address with no problem. I saw on some YouTube videos people do not have IP addresses for some VMs.
Any idea where it can be fixed? I do not restart NAS now, but I will check after the restart.
The problem is solved.
Need to have a guest OS agent. For Ubuntu/Debian these two should be executed
sudo apt install -y qemu-guest-agent
sudo systemctl start qemu-guest-agent
Almost immediately the IP addresses show up.
Yes! You need to install guest tools on any OS to get the IP to show up!
