Hello I am new to this forum and have a question about virtual machine.
my Synology DS918+ has 2 nic’s and they are on a different network.
in docker I can choose the different networks with a macvlan.
now I want to create 2 machines in virtual machine that are each on the different network.
Virtual machine is running and I see 1 default network, but when I add the other one it sees no network connection on the 2nd nic. what am I doing wrong or is this just not possible.
It should be possible. Can you show the Edit screen of the second network with the error?
Is there a LAN cable connected to a switch in the LAN2 port on the NAS?
it is solved, I reset my network on my synology and now it works
