What is the best way for me to use my NAS?
Hey guys, just looking for some advice. I’m starting out with my first Synology NAS (the DS1522+). I am starting my journey with video and photo editing, as well as website development. In my NAS I’ve got only 2x8tb HDD’s in a SHR RAID. The NAS is only connected on a 1GBe connection. I’m stuck with deciding how I should use my NAS, and how I should connect to it as I move around a lot and won’t be able to use a direct connection all the time.
At fist I was just going to always use Synology drive and keep my current work local on my MacBook which has a 2tb SSD. This way I’m not limited by my NAS HDD speeds and can edit fine without slowdowns. However this also means whenever I need to access a large file, I will have to wait for it to download first.
The other option I was thinking, was to use the open VPN solution, but now I don’t know if this will be too slow to edit on, how to go about if I want to download something, and then what do I do when I get home and connect directly. Will my editing software (Premier Pro) think that the file location switched? Should I use a mix of both solutions, if so when do I use one and when do I use the other?
Sorry I know I wrote a lot, but I’ve just reached a bit of a jam, any advice would be much appreciated!
Hello,
I have been searching your forum. Thank you for the videos and all the hard work. I bought a small DS223 with 2 8 GB disks. I don’t have the option as being described in this with the SSDs. I only wish I could. Looking to work remotely and edit videos. I don’t usually save any work to my laptop drive. I have used an external drive for years. Looking to work straight from my NAS if possible but it’s looking like maybe I should have a local file that syncs to my NAS. Can you point me in the right direction, please? Thank you so much!!!
You might consider using Synology Drive Server and Client on your NAS (server) and MacBook (client). This is essentially a sync tool between NAS and computer.
Does this work the same on windows? So I would have to have files saved to my computer then?
Yes, I suggest to safe files on your computer. After you finished a job, you could move them to the NAS.
